[Zurückgezogen] Keine Verbindung zwischen OWServer und PBM01
FabianG
Danksagung erhalten: 1 Mal
Beitrag von FabianG »
ich habe Probleme meinen PBM01 mittels einem Raspberry PI ans Laufen zu bekommen.
Die Installation erfolgte nach der Inbetriebnahme-Anleitung (https://cdn02.plentymarkets.com/zi7ugtq ... me_PBM.pdf).
Der OWServer startet, allerdings findet er den PBM nicht.
sudo systemctl status owserver
● owserver.service - Backend server for 1-wire control
   Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
  Drop-In: /etc/systemd/system/owserver.service.d
           └─override.conf
   Active: active (running) since Thu 2021-01-28 12:09:13 CET; 15s ago
     Docs: man:owserver(1)
 Main PID: 2029 (owserver)
    Tasks: 4 (limit: 881)
   CGroup: /system.slice/owserver.service
           └─2029 /usr/bin/owserver -c /etc/owfs.conf --foreground
Jan 28 12:09:07 raspberrypi systemd[1]: Starting Backend server for 1-wire control...
Jan 28 12:09:07 raspberrypi owserver[2029]: DEFAULT: ow_opt.c:(670) systemd mode -- ignore 'p' option
Jan 28 12:09:07 raspberrypi owserver[2029]: DEFAULT: ow_opt.c:(780) systemd mode -- ignore foreground request
Jan 28 12:09:12 raspberrypi owserver[2029]: DEFAULT: ow_elabnet.c:(145) PBM detection error
Jan 28 12:09:13 raspberrypi owserver[2029]: DEFAULT: owlib.c:(208) Cannot open USB bus master
Jan 28 12:09:13 raspberrypi systemd[1]: Started Backend server for 1-wire control.
Die dazugehörige owfs.conf
pi@raspberrypi:~ $ cat /etc/owfs.conf
# Sample configuration file for the OWFS suite for Debian GNU/Linux.
# This is the main OWFS configuration file. You should read the
# owfs.conf(5) manual page in order to understand the options listed
# here.
######################## SOURCES ########################
# With this setup, any client (but owserver) uses owserver on the
# local machine...
! server: server = localhost:4304
# ...and owserver uses the real hardware, by default fake devices
# This part must be changed on real installation
# server: FAKE = DS18S20,DS2405
# USB device: DS9490
#server: usb = all
# Serial port: DS9097
#server: device = /dev/ttyS1
# owserver tcp address
#server: server = 192.168.10.1:3131
# random simulated device
#server: FAKE = DS18S20,DS2405
######################### OWFS ##########################
mountpoint = /mnt/1wire
allow_other
####################### OWHTTPD #########################
http: port = 2121
####################### OWFTPD ##########################
ftp: port = 2120
####################### OWSERVER ########################
server: port = localhost:4304
server: usb = all
server: usb = scan
pbm = /dev/ttyUSB-PBM01-USB-BM_00000973
Die Version des OWServer ist 3.2.p3
Im syslog kann man auch nicht mehr erkenne wie im Status.
Jemand eine Idee, wo der Fehler sein könnte?
Besten Dank
