[Beantwortet] [V3.5.1] MQTT Mosquitto Socket error
bmm85
Danksagung erhalten: 2 Mal
Beitrag von bmm85 »
Hi Forenfreunde,
hat jemand das gleiche Verhalten mit seinem Mosquitto ?
Bei mir connecten die Clients sauber auf den Broker.
Nach einiger Zeit fangen alle an und bekommen nur noch Socket error im mosquitto log und müssen reconnecten, was die Übertragung der Nachrichten verzögert....
Habe es nach dem Tutorial hier aus dem Forum auf den TWS3500 deployed und laufe mit default config. Sprich anonymoous und default port.
1675795354: New client connected from 192.168.195.71 as ESP8266Client-21b0 (p2, c1, k15).
1675795361: Socket error on client ESP8266Client-5e4f, disconnecting.
1675795361: New connection from 192.168.195.62 on port 1883.
1675795361: New client connected from 192.168.195.62 as ESP8266Client-71c5 (p2, c1, k15).
1675795382: Socket error on client ESP8266Client-71c5, disconnecting.
1675795383: New connection from 192.168.195.62 on port 1883.
1675795383: New client connected from 192.168.195.62 as ESP8266Client-6824 (p2, c1, k15).
1675795388: Socket error on client ESP8266Client-21b0, disconnecting.
1675795388: New connection from 192.168.195.71 on port 1883.
1675795388: New client connected from 192.168.195.71 as ESP8266Client-9a68 (p2, c1, k15).
1675795414: Socket error on client ESP8266Client-9a68, disconnecting.
1675795415: New connection from 192.168.195.71 on port 1883.
1675795415: New client connected from 192.168.195.71 as ESP8266Client-4c1a (p2, c1, k15).
1675795420: Socket error on client ESP8266Client-6824, disconnecting.
1675795420: New connection from 192.168.195.62 on port 1883.
1675795420: New client connected from 192.168.195.62 as ESP8266Client-5df8 (p2, c1, k15).
1675795421: Socket error on client ESP8266Client-5df8, disconnecting.
1675795421: New connection from 192.168.195.62 on port 1883.
1675795421: New client connected from 192.168.195.62 as ESP8266Client-24cf (p2, c1, k15).
1675795433: Socket error on client ESP8266Client-4c1a, disconnecting.
1675795433: New connection from 192.168.195.71 on port 1883.
1675795433: New client connected from 192.168.195.71 as ESP8266Client-187b (p2, c1, k15).
1675795448: Socket error on client ESP8266Client-24cf, disconnecting.
1675795448: New connection from 192.168.195.62 on port 1883.
1675795448: New client connected from 192.168.195.62 as ESP8266Client-44da (p2, c1, k15).
1675795451: Socket error on client ESP8266Client-187b, disconnecting.
1675795451: New connection from 192.168.195.71 on port 1883.
1675795451: New client connected from 192.168.195.71 as ESP8266Client-e3f8 (p2, c1, k15).
Zuletzt geändert von Parsley am Do Nov 09, 2023 11:20 pm, insgesamt 1-mal geändert.
TWS 3500L ID:1047 / VPN offen/ Reboot nur nach Absprache
Danksagung erhalten: 2103 Mal
Ich wüsste nicht mal wo ich mir so ein Log anschauen könnte. Habe das so daher noch nicht feststellen können.
Hat sich bedankt: 935 Mal
Danksagung erhalten: 478 Mal
Beitrag von Parsley »
Hallo @bmm85
Willkommen im Forum.
Bitte trage in deiner Signatur von die Informationen zu deinen Server ein (ID und VPN). Danke ;)
bmm85
Beitrag von bmm85 »
Nachschauen kannst du das hier
Hat sich bedankt: 2255 Mal
Danksagung erhalten: 947 Mal
Ich kann die Probleme bei mir nicht nachvollziehen, aber ich habe auch die Version 2.x auf meinem System am laufen. Bei dir handelt es sicher um die 1.6 Version.
Hat sich bedankt: 452 Mal
Danksagung erhalten: 250 Mal
@bmm85
Noch mal die Bitte deine Signatur auszufüllen.
Ohne korrekt ausgefüllte Signatur, werden es sich die Wissensträger nicht ansehen, weil einfach Informationen fehlen. Was in die Signatur gehört steht in den Forenregeln
https://wiki.timberwolf.io/Forenregeln
Danke für deine Mithilfe
Zuletzt geändert von Mibr85 am Mi Feb 08, 2023 9:29 am, insgesamt 1-mal geändert.
Moin
Danke @bmm85 für das setzen deiner Signatur. :)
Ich kann leider nicht sagen ob das bei mir so richtig ist, aber bei mir sieht es gerade so aus:
1675844451: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
1675845605: Client DVES_FA3497 has exceeded timeout, disconnecting.
1675845606: New connection from 192.168.78.23 on port 1883.
1675845606: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
1675845675: Client DVES_FA3497 has exceeded timeout, disconnecting.
1675845678: New connection from 192.168.78.23 on port 1883.
1675845678: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
1675845958: Client timberwolf657 has exceeded timeout, disconnecting.
1675845971: New connection from 172.17.0.1 on port 1883.
1675845972: New client connected from 172.17.0.1 as timberwolf657 (p2, c1, k60, u'timberwolf').
1675846575: Client DVES_FA3497 has exceeded timeout, disconnecting.
1675846577: New connection from 192.168.78.23 on port 1883.
1675846577: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
1675846818: New connection from 192.168.78.23 on port 1883.
1675846818: Client DVES_FA3497 already connected, closing old connection.
1675846818: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
1675847600: Client timberwolf657 has exceeded timeout, disconnecting.
1675847600: New connection from 172.17.0.1 on port 1883.
1675847600: New client connected from 172.17.0.1 as timberwolf657 (p1, c1, k60, u'timberwolf').
1675847691: Client timberwolf657 has exceeded timeout, disconnecting.
1675847704: New connection from 172.17.0.1 on port 1883.
1675847704: New client connected from 172.17.0.1 as timberwolf657 (p2, c1, k60, u'timberwolf').
1675847825: Client DVES_FA3497 has exceeded timeout, disconnecting.
1675847825: New connection from 192.168.78.23 on port 1883.
1675847825: New client connected from 192.168.78.23 as DVES_FA3497 (p2, c1, k30, u'tasmotaIRlesekopf').
Mein Mosquitto ist 1.6.15.
Hallo @bmm85
Ist das Thema für dich gelöst?
Zurück zu „MQTT“
