[FINR] [V 3.4.3] Bearer token truncated at 255 characters? (WD-2224)
tark1
Hat sich bedankt: 15 Mal
Beitrag von tark1 »
I am trying to set up an HTTP API connection with Husqvarna Automower in TW (v 3.4.3), and keep getting authentication errors, at the same time everything is working properly using the same credentials in Postman.
After some investigation it seems to me that the full token (938 characters in this case) is not passed on in the request and only the first 255 characters are, at least it seems so in the TW GUI - see screenshot below.
Is there a way to see the full headers of the request so that I could confirm my concern?
Zuletzt geändert von tark1 am Do Aug 04, 2022 9:45 pm, insgesamt 3-mal geändert.
TW3500 #827
bondt
Hat sich bedankt: 667 Mal
Danksagung erhalten: 239 Mal
Beitrag von bondt »
Hi @tark1,
Thanks for your message and documentation.
We have not come across any headers surpassing 255 characters in our test, but when trying to reproduce this, I can say that only the first 255 characters are being received by the receiver.
I've marked this topic as confirmed bug and assigned it WD-2224.
Michaël
Hat sich bedankt: 1540 Mal
@tark1
Could you please add the TWS Software Version installed on your TWS?
Hat sich bedankt: 434 Mal
Danksagung erhalten: 1045 Mal
Fixed in current version V 3.4.5 respectively RC 8.
Best regards,
Zuletzt geändert von ms20de am Mo Aug 22, 2022 5:47 pm, insgesamt 1-mal geändert.
Hat sich bedankt: 940 Mal
Danksagung erhalten: 636 Mal
Beitrag von Parsley »
Just like everybody has to add the version in the topic it would make sense to write „fixed in [V x.y.z]“. Or does it?
