Alle wichtigen Bekanntmachungen und Regeln über das Forum
Hallo Foristen,
heute hatten wir einen kurzen Ausfall des Forums (Update-Server, Shop usw. von uns waren davon nicht betroffen)
AWS schreibt dazu:
5:29 AM PDT We are investigating increased error rates and latencies for the EC2 APIs and connectivity issues for some instances in a single Availability Zone in the EU-CENTRAL-1 Region
6:05 AM PDT We are seeing increased error rates and latencies for the RunInstances and CreateSnapshot APIs, and increased connectivity issues for some instances in a single Availability Zone (euc1-az3) in the EU-CENTRAL-1 Region.
We have resolved the networking issues that affected the majority of instances within the affected Availability Zone, but continue to work on some instances that are experiencing degraded performance for some EBS volumes.
Other Availability Zones are not affected by this issue. We would recommend failing away from the affected Availability Zone until this issue has been resolved.
Zuletzt geändert von StefanW am Di Jul 13, 2021 3:20 pm, insgesamt 3-mal geändert.
Support für Timberwolf Server, 1-Wire und BlitzART Bitte WIKI lesen. Allg. Support nur im Forum. Bitte keine PN
