[Beantwortet] [V4.0 IP9] Hilfe bei Dateninterpretation
0lek
Hat sich bedankt: 24 Mal
Danksagung erhalten: 97 Mal
Beitrag von 0lek »
Ich bin auf keinen besseren Titel gekommen. Ich brauch etwas Hilfe bei der Interpretation von Daten aus einem HTTP-API und wie ich diese in die InfluxDB kriege.
Was will ich machen?
Daten aus einem PM10 (Smog) Sensor in die InfluxDB und weiter in Grafana bringen
Welche Daten
Ich bekomme die Daten ueber die API als Stunden-Durchschnitt. Hier der API-Link.
{"key":"PM10","values":[{"date":"2024-04-14 00:00:00","value":null},{"date":"2024-04-13 23:00:00","value":null},{"date":"2024-04-13 22:00:00","value":47.1014},{"date":"2024-04-13 21:00:00","value":29.4315},{"date":"2024-04-13 20:00:00","value":26.969},{"date":"2024-04-13 19:00:00","value":19.2261},{"date":"2024-04-13 18:00:00","value":13.6227},{"date":"2024-04-13 17:00:00","value":17.4531},{"date":"2024-04-13 16:00:00","value":15.408},{"date":"2024-04-13 15:00:00","value":19.6642},{"date":"2024-04-13 14:00:00","value":22.4598},{"date":"2024-04-13 13:00:00","value":20.917},{"date":"2024-04-13 12:00:00","value":22.4817},{"date":"2024-04-13 11:00:00","value":26.0218},{"date":"2024-04-13 10:00:00","value":28.5203},{"date":"2024-04-13 09:00:00","value":30.0228},{"date":"2024-04-13 08:00:00","value":34.3197},{"date":"2024-04-13 07:00:00","value":39.7655},{"date":"2024-04-13 06:00:00","value":45.2811},{"date":"2024-04-13 05:00:00","value":40.2013},{"date":"2024-04-13 04:00:00","value":39.4061},{"date":"2024-04-13 03:00:00","value":39.4717},{"date":"2024-04-13 02:00:00","value":45.1994},{"date":"2024-04-13 01:00:00","value":53.3304},{"date":"2024-04-13 00:00:00","value":49.5936},{"date":"2024-04-12 23:00:00","value":44.5269},{"date":"2024-04-12 22:00:00","value":45.888},{"date":"2024-04-12 21:00:00","value":null},{"date":"2024-04-12 20:00:00","value":25.8567},{"date":"2024-04-12 19:00:00","value":30.6745},{"date":"2024-04-12 18:00:00","value":25.3573},{"date":"2024-04-12 17:00:00","value":25.2729},{"date":"2024-04-12 16:00:00","value":18.7357},{"date":"2024-04-12 15:00:00","value":21.3768},{"date":"2024-04-12 14:00:00","value":20.8551},{"date":"2024-04-12 13:00:00","value":17.1416},{"date":"2024-04-12 12:00:00","value":21.2267},{"date":"2024-04-12 11:00:00","value":30.914},{"date":"2024-04-12 10:00:00","value":43.5125},{"date":"2024-04-12 09:00:00","value":61.0938},{"date":"2024-04-12 08:00:00","value":65.0691},{"date":"2024-04-12 07:00:00","value":53.0703},{"date":"2024-04-12 06:00:00","value":50.2484},{"date":"2024-04-12 05:00:00","value":45.0144},{"date":"2024-04-12 04:00:00","value":44.6426},{"date":"2024-04-12 03:00:00","value":44.7471},{"date":"2024-04-12 02:00:00","value":42.7786},{"date":"2024-04-12 01:00:00","value":null}]}
Ich kriege die Daten ueber den Selektor
values[1].value
auch raus.
Was ist denn dann das Problem?
Vielleicht ist es nur ein Verstaendnissproblem. Soll ich nur den "value" in die Influxdb schreiben? Und den Timestamp generiert die DB? Oder lieber beides? Aber kann ich dann diesen Timestamp fuer die Zeitachse bei Grafana nutzen?
Oder einfach besser die Transaktion alle 60 Minuten laufen lassen, und dann so getimed dass es zur vollen Stude ist? Dann waeren die Timestamps aus dem JSON und in der InfluxDB ja mehr oder weniger synchronisiert.
Danke fuer Eure Hilfe!
Aleksander
Zuletzt geändert von Mibr85 am So Apr 14, 2024 1:03 am, insgesamt 1-mal geändert.
Hat sich bedankt: 1537 Mal
Danksagung erhalten: 2103 Mal
In der TWS-Instanz Influxdb kannst Du nur den Value speichern. Die Randattribute ergeben sich dabei selbst.
Wenn Du eine eigene Influxdb in einem Container hostest, kannst Du es auch zu einem eigenen definierten Zeitstempel speichern.
Die Lösung ist TWS nativ, ein stündlich getriggerter API Abruf.
0lek
Beitrag von 0lek »
@gbglace Danke. War auch mein Verstaendniss.
Ich habe hier noch einen Fall. Ich wuerde das mal in dem Topic belassen, weil es auf dem vorher aufbaut. Und zwar habe ich folgende
Daten.
Das sind Strahlenwerte. Ich habe leider kein API-Dokumentation dazu gefunden. Ich kann die Daten nach bestimmten Zeitraeumen (mit "dateFrom" und "dateTo" in URL) begrenzen.
Wie wuerde ich jetzt vorgehen, wenn ich das in die Influx schreiben moechte? Die Wette gibt es ja stuendlich, aber wie kann ich eine "dynamische" URL generieren fuer HTTP Abfrage?
Wuerde ich das in Python umsetzen, wuerde ich wahrscheinlich sowas machen, wie: bei "dateFrom" now - 1h und bei "dateTo" now, dann CURL laufen lassen. Klar, kann ich das machen, aber wuerde es lieber nativ auf dem TWS umsetzen.
Oder vielleicht mal etwas generischer gefragt: Wie gehe ich mit APIs um, die mir nicht den aktuellen Wert sondern eine Zeitreihe geben?
Danke!
Zuletzt geändert von 0lek am Di Apr 16, 2024 11:16 am, insgesamt 1-mal geändert.
Das ist eine ähnliche Aufgabe wie gezielt die Stundenpreise aus der Tibber-API abzufragen. Wobei Du das hier in einer Logik vor dem API-Aufruf basteln musst, beim Tibber brauchst das um den passenden Wert aus dem Antwort-JSON zu extrahieren.
Bei solchen JSON Arrays wo man eine fixe Anzahl an Objekten bekommt, musst eigentlich nur wissen die wievielte Stunde des Tages ist JETZT, dann kennst eigentlich immer die genaue Position im Array und kannst die passenden Werte dann aus der Gesamt-Antwort einfach selektieren.
Die Kunst besteht dann eigentlich immer nur eine Build-In Funktion zu haben, die einem als quasi einfache Zahl die laufende Sekunde/Minute/Stunde/Tag/Monat/Jahr liefert.
Aus einem String geht das dann noch mit Substrings usw. und da hat der TWs ja passende Logikbausteine um Stringsoperationen durchzuführen. nur seinen eigenen internen Unix-Zeitstempel bekommst eben so nicht zerlegt. Daher läuft das bei mir noch im NR.
MrWilson
Hat sich bedankt: 46 Mal
Danksagung erhalten: 170 Mal
Beitrag von MrWilson »
Du setzt den Wert für dateFrom und dateTo in der URI in <> mit einem Namen und erstellst dann zwei Abfragen, die Start- und Endzeit aus einer Logik z.B. kommend, an die URI übergeben.
