[Gelöst] ow_elabnet.c:(231) PBM: detection error
rdorsch
Hat sich bedankt: 1 Mal
Beitrag von rdorsch »
ich beobachte seit ein paar Tagen, dass um ca. 06:30 Uhr das Auslesen von Temperatursensoren scheitert, z.B.
owget /28.FFA620841603/temperature
produziert
ServerRead: Data error on /28.FFA620841603/temperature
Ich habe daraufhin im systemd journal geschaut und sehe folgendes Problem:
rd@home:~/git.nobackup/sh$ journalctl -u owfs.service
-- Logs begin at Sat 2020-10-10 06:03:46 CEST, end at Sat 2020-10-10 12:37:43 CEST. --
Oct 10 06:25:07 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:25:08 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
Oct 10 06:25:08 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:25:19 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:25:19 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 10 06:25:49 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:25:49 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
Oct 10 06:25:49 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:26:21 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:26:22 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 10 06:27:00 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:27:05 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:27:21 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:27:31 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:27:53 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:27:53 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
Oct 10 06:28:03 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:28:03 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 10 06:28:03 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:28:14 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:28:31 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:28:58 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:29:09 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:29:09 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:29:14 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:29:19 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:29:36 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:29:42 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:29:43 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 10 06:29:49 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:30:07 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:30:18 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:30:18 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 10 06:30:25 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:30:46 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:30:58 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 10 06:31:03 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:31:03 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 10 06:32:16 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:32:16 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 10 06:32:39 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 10 06:32:44 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 10 06:32:44 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
Oct 10 06:32:45 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Die passende Stelle in ow_elabnet.c ist:
static GOOD_OR_BAD PBM_reconnect( const struct parsedname  *pn )
        struct connection_in * in = pn->selected_connection ;
        struct port_in * pin = in->pown ;
        COM_close(in->master.pbm.head ) ;
        pin->baud = B9600;
        RETURN_BAD_IF_BAD( COM_open(in->master.pbm.head ) ) ;
        if ( BAD( PBM_version(in, NULL) )) {
                COM_close(in) ;
                LEVEL_DEFAULT("PBM: detection error");
                return gbBAD;
        pin->baud = B115200;
        PBM_set_baud(in);
        return gbGOOD;
Kann jemand sagen, welcher Fehler reported wird? Ist tatsächlich der PBM selbst nicht erreichbar? Was könnte die Ursache sein?
Danke und Gruß
Rainer
Debian 11, Kernel 5.10.0, PBM
Hat sich bedankt: 1511 Mal
Danksagung erhalten: 2058 Mal
Hallo Rainer,
Du kannst bestimmt noch etwas über Deine Anlage zur Orientierung des Problems schreiben. Das schaut mir alles nicht nach einem PBM an einem TWs angeschlossen aus.
Ganz grob würde ich sagen hat das mit einem PBM und den Sensoren nichts zu tun, weil der keine Uhrzeit kennt oder benötigt oder irgendwie mit LAN usw. was zu tun hat.
Support Für alles serverartiges ungleich TWS wird hier aber eher schwer zu bekommen.
Hat sich bedankt: 432 Mal
Danksagung erhalten: 905 Mal
Hallo Rainer,
ich würde auf der Stromversorgungs- oder USB-Seite zu suchen. USB-Kabel, Hubs und Stecker können die Ursache sein. Untersuche den Syslog zu dem Zeitpunkt nach USB-Meldungen.
Hat sich bedankt: 2189 Mal
Danksagung erhalten: 922 Mal
Hallo Rainer @rdorsch Bitte noch deine Signatur anpassen wie wir sie alle haben. Damit ist es für den Support einfacher.
Danke dir.
rdorsch
Ich betreibe den PBM an einem Debian 10 Server. Mir ist durchaus klar, dass der PBM nicht die Ursache des Problems sein muss, aber er meldet nun halt mal einen Fehler, deshalb muss ich dort anfangen mit dem Debuggen.
Problem taucht täglich auf:
rd@home:~$ journalctl -u owfs.service
-- Logs begin at Mon 2020-10-12 01:35:01 CEST, end at Mon 2020-10-12 08:11:17 CEST. --
Oct 12 06:25:05 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:25:10 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:25:10 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:25:16 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:25:21 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:25:21 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:25:21 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:25:47 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:25:53 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:26:19 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:26:19 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:26:24 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:26:24 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:26:55 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:27:13 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:27:13 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:27:18 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:27:23 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:27:23 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:27:24 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:27:42 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:27:42 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:28:44 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:28:50 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:28:50 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:30:06 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:30:11 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:30:11 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:30:16 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:30:17 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:31:14 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:31:19 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:31:20 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:32:37 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:32:37 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:32:47 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:32:47 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:32:48 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:32:59 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:32:59 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
Oct 12 06:33:40 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:33:45 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:33:45 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(1) bus master!
Oct 12 06:33:54 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:34:10 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:34:15 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:34:15 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:34:26 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:34:59 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:35:21 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:35:37 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(1) bus master reconnected
Oct 12 06:35:42 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(0) bus master reconnected
Oct 12 06:35:47 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:35:47 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(0) bus master!
Oct 12 06:35:53 home OWFS[471]: DEFAULT: ow_reconnect.c:(71) PBM(2) bus master reconnected
Oct 12 06:35:58 home OWFS[471]: DEFAULT: ow_elabnet.c:(231) PBM: detection error
Oct 12 06:35:58 home OWFS[471]: DEFAULT: ow_reconnect.c:(69) Failed to reconnect PBM(2) bus master!
rd@home:~$
Ich habe mal im systemd journal nachgeschaut, das Einzige was ich halbwegs
Oct 12 06:20:01 home CRON[2980]: (rd) CMD (/home/rd/git.nobackup/Fronius_PVOutput_Uploader/update-fronius.sh)
Oct 12 06:20:01 home CRON[2964]: pam_unix(cron:session): session closed for user root
Oct 12 06:20:01 home CRON[2971]: pam_unix(cron:session): session closed for user sh
Oct 12 06:20:01 home CRON[2965]: pam_unix(cron:session): session closed for user rd
Oct 12 06:20:02 home CRON[2967]: pam_unix(cron:session): session closed for user rd
Oct 12 06:20:02 home CRON[2968]: pam_unix(cron:session): session closed for user rd
Oct 12 06:20:02 home CRON[2966]: pam_unix(cron:session): session closed for user rd
Oct 12 06:20:04 home CRON[2969]: pam_unix(cron:session): session closed for user rd
Oct 12 06:20:13 home CRON[2970]: pam_unix(cron:session): session closed for user rd
Oct 12 06:21:01 home CRON[6065]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:21:01 home CRON[6066]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:21:01 home CRON[6067]: (rd) CMD (PATH=/usr/local/bin:$PATH /home/sh/git/sh/bin/log-temp.sh >> /var/smarthome/logs/indoor-temp.log)
Oct 12 06:21:01 home CRON[6068]: (rd) CMD ((cd /var/smarthome/fronius; python3 ~/git.nobackup/fronius-json-tools/livedata2db.py))
Oct 12 06:21:04 home CRON[6066]: pam_unix(cron:session): session closed for user rd
Oct 12 06:21:16 home CRON[6065]: pam_unix(cron:session): session closed for user rd
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 available DHCP range: 192.168.7.2 -- 192.168.7.230
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 vendor class: dhcpcd-8.1.2:Linux-5.4.51-v7l+:armv7l:BCM2711
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 client provides name: raspberrypi
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 DHCPREQUEST(eth0.7) 192.168.7.50 dc:a6:32:4d:dc:db
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 tags: data, known, eth0.7
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 DHCPACK(eth0.7) 192.168.7.50 dc:a6:32:4d:dc:db raspi4
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 requested options: 1:netmask, 121:classless-static-route, 33:static-route,
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 requested options: 3:router, 6:dns-server, 12:hostname, 15:domain-name,
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 requested options: 26:mtu, 28:broadcast, 51:lease-time, 54:server-identifier,
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 requested options: 58:T1, 59:T2, 119:domain-search
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 next server: 192.168.7.1
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  1 option: 53 message-type  5
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option: 54 server-identifier  192.168.7.1
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option: 51 lease-time  12h
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option: 58 T1  5h37m29s
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option: 59 T2  10h7m29s
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option:  1 netmask  255.255.255.0
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option: 28 broadcast  192.168.7.255
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option:  3 router  192.168.7.1
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  4 option:  6 dns-server  192.168.7.1
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size: 11 option: 15 domain-name  bokomoko.de
Oct 12 06:21:30 home dnsmasq-dhcp[3899]: 2191151236 sent size:  6 option: 12 hostname  raspi4
Oct 12 06:22:01 home CRON[8045]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:22:01 home CRON[8044]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:22:01 home CRON[8047]: (rd) CMD (/home/rd/git.nobackup/Fronius_PVOutput_Uploader/update-fronius.sh)
Oct 12 06:22:01 home CRON[8046]: (rd) CMD ((cd /var/smarthome/fronius; python3 ~/git.nobackup/fronius-json-tools/livedata2db.py))
Oct 12 06:22:03 home CRON[8044]: pam_unix(cron:session): session closed for user rd
Oct 12 06:22:13 home CRON[8045]: pam_unix(cron:session): session closed for user rd
Oct 12 06:23:01 home CRON[10002]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:23:01 home CRON[10004]: (rd) CMD ((cd /var/smarthome/fronius; python3 ~/git.nobackup/fronius-json-tools/livedata2db.py))
Oct 12 06:23:04 home CRON[10002]: pam_unix(cron:session): session closed for user rd
Oct 12 06:24:01 home CRON[11921]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:24:01 home CRON[11922]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:24:01 home CRON[11924]: (rd) CMD ((cd /var/smarthome/fronius; python3 ~/git.nobackup/fronius-json-tools/livedata2db.py))
Oct 12 06:24:01 home CRON[11923]: (rd) CMD (/home/rd/git.nobackup/Fronius_PVOutput_Uploader/update-fronius.sh)
Oct 12 06:24:03 home CRON[11921]: pam_unix(cron:session): session closed for user rd
Oct 12 06:24:13 home CRON[11922]: pam_unix(cron:session): session closed for user rd
Oct 12 06:25:01 home CRON[13793]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 12 06:25:01 home CRON[13791]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 12 06:25:01 home CRON[13801]: (root) CMD (PATH=$PATH:/usr/sbin /usr/local/bin/watch-sip.sh)
Oct 12 06:25:01 home CRON[13800]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
Oct 12 06:25:01 home CRON[13797]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:25:01 home CRON[13796]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:25:01 home CRON[13795]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:25:01 home CRON[13803]: (rd) CMD (PATH=/usr/local/bin:$PATH update-zehnder.sh)
Oct 12 06:25:01 home CRON[13799]: pam_unix(cron:session): session opened for user sh by (uid=0)
Oct 12 06:25:01 home CRON[13804]: (rd) CMD (PATH=/usr/local/bin:$PATH pub_outTemp.sh)
Oct 12 06:25:01 home CRON[13802]: (rd) CMD (/usr/local/bin/log-mtec.py >> /var/smarthome/logs/mtec.log)
Oct 12 06:25:01 home CRON[13794]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:25:01 home CRON[13806]: (sh) CMD (/usr/local/bin/alloff.sh)
Oct 12 06:25:01 home CRON[13807]: (rd) CMD (/usr/local/bin/presence2mqtt.sh)
Oct 12 06:25:01 home CRON[13798]: pam_unix(cron:session): session opened for user rd by (uid=0)
Oct 12 06:25:01 home CRON[13813]: (rd) CMD ((cd /var/smarthome/fronius; python3 ~/git.nobackup/fronius-json-tools/livedata2db.py))
Oct 12 06:25:01 home CRON[13792]: pam_unix(cron:session): session opened for user root by (uid=0)
Oct 12 06:25:01 home CRON[13817]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Oct 12 06:25:01 home CRON[13792]: pam_unix(cron:session): session closed for user root
Oct 12 06:25:01 home CRON[13793]: pam_unix(cron:session): session closed for user root
Oct 12 06:25:01 home CRON[13799]: pam_unix(cron:session): session closed for user sh
Oct 12 06:25:02 home CRON[13794]: pam_unix(cron:session): session closed for user rd
Oct 12 06:25:02 home CRON[13796]: pam_unix(cron:session): session closed for user rd
Oct 12 06:25:02 home CRON[13795]: pam_unix(cron:session): session closed for user rd
Oct 12 06:25:02 home CRON[13797]: pam_unix(cron:session): session closed for user rd
Oct 12 06:25:05 home CRON[13798]: pam_unix(cron:session): session closed for user rd
das Einzige was mir auffällt, ist dass der anacron kurz vorher losläuft
allerdings finde ich darin zunächst auch nichts Verdächtiges, zumal alles unmodifizierte Debian Skripte sind
rd@home:~$ ls -l /etc/cron.daily/
total 64
-rwxr-xr-x 1 root root  539 Jan 25  2017 apache2
-rwxr-xr-x 1 root root 1478 May 28  2019 apt-compat
-rwxr-xr-x 1 root root  314 Nov  8  2014 aptitude
-rwxr-xr-x 1 root root  355 Oct 17  2014 bsdmainutils
-rwxr-xr-x 1 root root 1187 Apr 19  2019 dpkg
-rwxr-xr-x 1 root root  205 Jul 18  2016 etckeeper
-rwxr-xr-x 1 root root 4128 Sep 27  2019 exim4-base
-rwxr-xr-x 1 root root  377 Aug 29  2018 logrotate
-rwxr-xr-x 1 root root 1123 Feb 10  2019 man-db
-rwxr-xr-x 1 root root  543 Nov 14  2018 mlocate
-rwxr-xr-x 1 root root 1403 Mar 21  2019 ntp
-rwxr-xr-x 1 root root  249 Nov 19  2015 passwd
-rwxr-xr-x 1 root root 4571 May 20  2018 popularity-contest
-rwxr-xr-x 1 root root  441 May 25  2017 sysstat
rd@home:~$
Womit ich wieder zurück bin beim Anfang: Woran stört sich owfs bzw. PBM?
Danke und Gruß
Rainer
Hat sich bedankt: 5465 Mal
Danksagung erhalten: 9474 Mal
Hallo Rainer,
es tut mir sehr leid, dass Du Probleme hast mit Deinem selbst aufgesetzten Server.
rdorsch hat geschrieben: Mo Okt 12, 2020 8:48 amMir ist durchaus klar, dass der PBM nicht die Ursache des Problems sein muss, aber er meldet nun halt mal einen Fehler, deshalb muss ich dort anfangen mit dem Debuggen.
Es ist das OWFS das einen Fehler meldet. Zwischen dem OWFS und dem PBM liegt das ganze USB Subsystem und unserer Meinung nach könnte es lohnend sein, dort nach dem Fehler zu suchen.
Werbeeinblendung: Falls Dir eines Tages der Aufwand zu groß wird, wir haben den Timberwolf Server entwickelt, bei dem dies - und tausend andere Kleinigkeiten - ganz einwandfrei funktioniert und bei Problemen alles schnell in Ordnung gebracht wird. Da es am Ende dann doch nicht so einfach ist mit alle den kleinen fiesen Details, hat diese Entwicklung bisher 30 Mannjahre und damit 3 Millionen Euro gekostet - und jedes Jahr kommen 5 bis 7 Mannjahre dazu, damit der Server immer besser wird. Ich meine, das kann man privat nie aufholen und wird auch nie das gleiche Ergebnis bieten.
Wir wünschen viel Erfolg bei Deinem Projekt
Zuletzt geändert von StefanW am Mo Okt 12, 2020 10:28 am, insgesamt 4-mal geändert.
rdorsch
ich finde es schön, dass Ihr Komponenten mit offenen Schnittstellen liefert, auch wenn die Komponenten letztendlich proprietär sind. Den zentralen Server möchte ich jedoch keinesfalls auf eine proprietäre Plattform aufsetzen, daher passt der Timberwolf nicht und nur als Gateway zum 1w-Netzwerk ist er zu schade und zu teuer.
Die Werbeeinblendung wäre deutlich beeindruckender für mich, wenn ich bei einem 1-wire-Problem den Eindruck hätte, bei Euch sitzen Leute, deren Wissen ist bei Problemen so hilfreich für mich, dass ich es auch über 1-wire Themen hinaus gut gebrauchen könnte. Vielleicht ist das ja alles ganz anders, wenn jemand einen Timberwolf kauft und nicht nur einen PBM... ;-)
Rainer
Hat sich bedankt: 899 Mal
Danksagung erhalten: 1235 Mal
Hallo miteinander
rdorsch hat geschrieben: Mo Okt 12, 2020 9:28 pm Die Werbeeinblendung wäre deutlich beeindruckender für mich, wenn ich bei einem 1-wire-Problem den Eindruck hätte, bei Euch sitzen Leute, deren Wissen ist bei Problemen so hilfreich für mich, dass ich es auch über 1-wire Themen hinaus gut gebrauchen könnte. Vielleicht ist das ja alles ganz anders, wenn jemand einen Timberwolf kauft und nicht nur einen PBM... ;-)
Mit anderen Worten: Wenn Du den Support von Elabnet auch für andere Dinge in Anspruch nehmen könntest, welche nichts mit 1-Wire zu tun haben und ohne dafür (D)einen Anteil beizutragen.
Ja... nee... is klar... :confusion-scratchheadyellow:
Zuletzt geändert von starwarsfan am Di Okt 13, 2020 10:03 am, insgesamt 1-mal geändert.
rdorsch
starwarsfan hat geschrieben: Di Okt 13, 2020 7:52 am Mit anderen Worten: Wenn Du den Support von Elabnet auch für andere Dinge in Anspruch nehmen könntest, welche nichts mit 1-Wire zu tun haben und ohne dafür (D)einen Anteil beizutragen.
owfs=1-wire file system :angry-banghead:
"Problem" lies sich durch Reboot des Servers wg. Security-Update (zumindest temporär) lösen.
Rainer
Zuletzt geändert von rdorsch am Fr Okt 23, 2020 12:11 am, insgesamt 1-mal geändert.
