[Frage] Modbusmaster.php in Edomi Docker 2.0
jockele
Hat sich bedankt: 28 Mal
Danksagung erhalten: 61 Mal
Beitrag von jockele »
abgekoppelt aus dem Thread viewtopic.php?f=73&t=1841&start=70 hier nochmals die Anfrage für Unterstützung bei der Modifikation der Modbusmaster.php
Meine Modusmaster.php kommt aus dem E3DC Baustein (19000096), anbei der Code:
<?php
 * Phpmodbus Copyright (c) 2004, 2012 Jan Krakora
 * This source file is subject to the "PhpModbus license" that is bundled
 * with this package in the file license.txt.
 * @copyright  Copyright (c) 2004, 2012 Jan Krakora
 * @license PhpModbus license
 * @category Phpmodbus
 * @tutorial Phpmodbus.pkg
 * @package Phpmodbus
 * @version $id$
require_once dirname(__FILE__) . '/IecType.php';
require_once dirname(__FILE__) . '/PhpType.php';
 * ModbusMaster
 * This class deals with the MODBUS master
 * Implemented MODBUS master functions:
 *   - FC  1: read coils
 *   - FC  3: read multiple registers
 *   - FC 15: write multiple coils
 *   - FC 16: write multiple registers
 *   - FC 23: read write registers
 * @author Jan Krakora
class ModbusMaster {
  private $sock;
  public $host = "192.168.1.1";
  public $port = "502";
  public $client = "";
  public $client_port = "502";
  public $status;
  public $timeout_sec = 5; // Timeout 5 sec
  public $endianness = 0; // Endianness codding (little endian == 0, big endian == 1)
  public $socket_protocol = "UDP"; // Socket protocol (TCP, UDP)
   * ModbusMaster
   * This is the constructor that defines {@link $host} IP address of the object.
   * @param String $host An IP address of a Modbus TCP device. E.g. "192.168.1.1"
   * @param String $protocol Socket protocol (TCP, UDP)
  function ModbusMaster($host, $protocol){
    $this->socket_protocol = $protocol;
    $this->host = $host;
   * __toString
   * Magic method
  function  __toString() {
      return "<pre>" . $this->status . "</pre>";
   * connect
   * Connect the socket
   * @return bool
  private function connect(){
    // Create a protocol specific socket
    if ($this->socket_protocol == "TCP"){
        // TCP socket
        $this->sock = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
    } elseif ($this->socket_protocol == "UDP"){
        // UDP socket
        $this->sock = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
    } else {
        throw new Exception("Unknown socket protocol, should be 'TCP' or 'UDP'");
    // Bind the client socket to a specific local port
    if (strlen($this->client)>0){
        $result = socket_bind($this->sock, $this->client, $this->client_port);
        if ($result === false) {
            throw new Exception("socket_bind() failed.</br>Reason: ($result)".
                socket_strerror(socket_last_error($this->sock)));
        } else {
            $this->status .= "Bound\n";
    // Connect the socket
    $result = @socket_connect($this->sock, $this->host, $this->port);
        throw new Exception("socket_connect() failed.</br>Reason: ($result)".
    } else {
        $this->status .= "Connected\n";
        return true;
   * disconnect
   * Disconnect the socket
  private function disconnect(){
    socket_close($this->sock);
    $this->status .= "Disconnected\n";
   * send
   * Send the packet via Modbus
   * @param string $packet
  private function send($packet){
    socket_write($this->sock, $packet, strlen($packet));
    $this->status .= "Send\n";
   * rec
   * Receive data from the socket
   * @return bool
  private function rec(){
    socket_set_nonblock($this->sock);
    $readsocks[] = $this->sock;
    $writesocks = NULL;
    $exceptsocks = NULL;
    $rec = "";
    $lastAccess = time();
    while (socket_select($readsocks,
            $writesocks,
            $exceptsocks,
            0,
            300000) !== FALSE) {
            $this->status .= "Wait data ... \n";
        if (in_array($this->sock, $readsocks)) {
            while (@socket_recv($this->sock, $rec, 2000, 0)) {
                $this->status .= "Data received\n";
                return $rec;
        } else {
            if (time()-$lastAccess >= $this->timeout_sec) {
                throw new Exception( "Watchdog time expired [ " .
                  $this->timeout_sec . " sec]!!! Connection to " .
                  $this->host . " is not established.");
   * responseCode
   * Check the Modbus response code
   * @return bool
  private function responseCode($packet){
    if((ord($packet[7]) & 0x80) > 0) {
      // failure code
      $failure_code = ord($packet[8]);
      // failure code strings
      $failures = array(
        0x01 => "ILLEGAL FUNCTION",
        0x02 => "ILLEGAL DATA ADDRESS",
        0x03 => "ILLEGAL DATA VALUE",
        0x04 => "SLAVE DEVICE FAILURE",
        0x05 => "ACKNOWLEDGE",
        0x06 => "SLAVE DEVICE BUSY",
        0x08 => "MEMORY PARITY ERROR",
        0x0A => "GATEWAY PATH UNAVAILABLE",
        0x0B => "GATEWAY TARGET DEVICE FAILED TO RESPOND");
      // get failure string
      if(key_exists($failure_code, $failures)) {
        $failure_str = $failures[$failure_code];
      } else {
        $failure_str = "UNDEFINED FAILURE CODE";
      // exception response
      throw new Exception("Modbus response error code: $failure_code ($failure_str)");
    } else {
      $this->status .= "Modbus response error code: NOERROR\n";
      return true;
   * readCoils
   * Modbus function FC 1(0x01) - Read Coils
   * Reads {@link $quantity} of Coils (boolean) from reference
   * {@link $reference} of a memory of a Modbus device given by
   * {@link $unitId}.
   * @param type $unitId
   * @param type $reference
   * @param type $quantity
  function readCoils($unitId, $reference, $quantity){
    $this->status = "readCoils: START\n";
    // connect
    $this->connect();
    // send FC 1
    $packet = $this->readCoilsPacketBuilder($unitId, $reference, $quantity);
    $this->status .= $this->printPacket($packet);
    $this->send($packet);
    // receive response
    $rpacket = $this->rec();
    $this->status .= $this->printPacket($rpacket);
    // parse packet
    $receivedData = $this->readCoilsParser($rpacket, $quantity);
    // disconnect
    $this->disconnect();
    $this->status .= "readCoils: DONE\n";
    // return
    return $receivedData;
   * fc1
   * Alias to {@link readCoils} method
   * @return type
  function fc1($unitId, $reference, $quantity){
    return $this->readCoils($unitId, $reference, $quantity);
   * readCoilsPacketBuilder
   * FC1 packet builder - read coils
   * @return type
  private function readCoilsPacketBuilder($unitId, $reference, $quantity){
    $dataLen = 0;
    // build data section
    $buffer1 = "";
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(1);              // FC 1 = 1(0x01)
    // build body - read section
    $buffer2 .= iecType::iecINT($reference);      // refnumber = 12288
    $buffer2 .= iecType::iecINT($quantity);       // quantity
    $dataLen += 5;
    // build header
    $buffer3 = '';
    $buffer3 .= iecType::iecINT(rand(0,65000));   // transaction ID
    $buffer3 .= iecType::iecINT(0);               // protocol ID
    $buffer3 .= iecType::iecINT($dataLen + 1);    // lenght
    $buffer3 .= iecType::iecBYTE($unitId);        //unit ID
    // return packet string
    return $buffer3. $buffer2. $buffer1;
   * readCoilsParser
   * FC 1 response parser
   * @param type $packet
   * @return type
  private function readCoilsParser($packet, $quantity){
    $data = array();
    // check Response code
    $this->responseCode($packet);
    // get data from stream
    for($i=0;$i<ord($packet[8]);$i++){
      $data[$i] = ord($packet[9+$i]);
    // get bool values to array
    $data_bolean_array = array();
    $di = 0;
    foreach($data as $value){
      for($i=0;$i<8;$i++){
        if($di == $quantity) continue;
        // get boolean value
        $v = ($value >> $i) & 0x01;
        // build boolean array
        if($v == 0){
          $data_bolean_array[] = FALSE;
        } else {
          $data_bolean_array[] = TRUE;
        $di++;
    return $data_bolean_array;
   * readInputDiscretes
   * Modbus function FC 2(0x02) - Read Input Discretes
   * Reads {@link $quantity} of Inputs (boolean) from reference
   * {@link $unitId}.
  function readInputDiscretes($unitId, $reference, $quantity){
    $this->status = "readInputDiscretes: START\n";
    // connect
    $this->connect();
    // send FC 2
    $packet = $this->readInputDiscretesPacketBuilder($unitId, $reference, $quantity);
    // receive response
    // parse packet
    $receivedData = $this->readInputDiscretesParser($rpacket, $quantity);
    // disconnect
    $this->status .= "readInputDiscretes: DONE\n";
    // return
   * fc2
   * Alias to {@link readInputDiscretes} method
   * @return type
  function fc2($unitId, $reference, $quantity){
    return $this->readInputDiscretes($unitId, $reference, $quantity);
   * readInputDiscretesPacketBuilder
   * FC2 packet builder - read coils
   * @return type
  private function readInputDiscretesPacketBuilder($unitId, $reference, $quantity){
    $dataLen = 0;
    $buffer1 = "";
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(2);              // FC 2 = 2(0x02)
    $dataLen += 5;
    // build header
    $buffer3 = '';
   * readInputDiscretesParser
   * FC 2 response parser, alias to FC 1 parser i.e. readCoilsParser.
   * @return type
  private function readInputDiscretesParser($packet, $quantity){
    return $this->readCoilsParser($packet, $quantity);
   * readMultipleRegisters
   * Modbus function FC 3(0x03) - Read Multiple Registers.
   * This function reads {@link $quantity} of Words (2 bytes) from reference
   * {@link $referenceRead} of a memory of a Modbus device given by
   * {@link $unitId}.
   * @param int $unitId usually ID of Modbus device
   * @param int $reference Reference in the device memory to read data (e.g. in device WAGO 750-841, memory MW0 starts at address 12288).
   * @param int $quantity Amounth of the data to be read from device.
   * @return false|Array Success flag or array of received data.
  function readMultipleRegisters($unitId, $reference, $quantity){
    $this->status = "readMultipleRegisters: START\n";
    // connect
    $this->connect();
    // send FC 3
    $packet = $this->readMultipleRegistersPacketBuilder($unitId, $reference, $quantity);
    // receive response
    // parse packet
    $receivedData = $this->readMultipleRegistersParser($rpacket);
    // disconnect
    $this->status .= "readMultipleRegisters: DONE\n";
    // return
   * fc3
   * Alias to {@link readMultipleRegisters} method.
  function fc3($unitId, $reference, $quantity){
    return $this->readMultipleRegisters($unitId, $reference, $quantity);
   * readMultipleRegistersPacketBuilder
   * Packet FC 3 builder - read multiple registers
   * @return string
  private function readMultipleRegistersPacketBuilder($unitId, $reference, $quantity){
    $dataLen = 0;
    $buffer1 = "";
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(3);             // FC 3 = 3(0x03)
    $dataLen += 5;
    // build header
    $buffer3 = '';
   * readMultipleRegistersParser
   * FC 3 response parser
   * @return array
  private function readMultipleRegistersParser($packet){
    $data = array();
    // get data
    return $data;
   * writeMultipleCoils
   * Modbus function FC15(0x0F) - Write Multiple Coils
   * This function writes {@link $data} array at {@link $reference} position of
   * memory of a Modbus device given by {@link $unitId}.
   * @param type $data
   * @return type
  function writeMultipleCoils($unitId, $reference, $data){
    $this->status = "writeMultipleCoils: START\n";
    // connect
    $this->connect();
    // send FC16
    $packet = $this->writeMultipleCoilsPacketBuilder($unitId, $reference, $data);
    // receive response
    // parse packet
    $this->writeMultipleCoilsParser($rpacket);
    // disconnect
    $this->status .= "writeMultipleCoils: DONE\n";
    return true;
   * fc15
   * Alias to {@link writeMultipleCoils} method
   * @param array $data
   * @return bool
  function fc15($unitId, $reference, $data){
    return $this->writeMultipleCoils($unitId, $reference, $data);
   * writeMultipleCoilsPacketBuilder
   * Packet builder FC15 - Write multiple coils
   * @return string
  private function writeMultipleCoilsPacketBuilder($unitId, $reference, $data){
    $dataLen = 0;
    // build bool stream to the WORD array
    $data_word_stream = array();
    $data_word = 0;
    $shift = 0;
    for($i=0;$i<count($data);$i++) {
      if((($i % 8) == 0) && ($i > 0)) {
        $data_word_stream[] = $data_word;
        $shift = 0;
        $data_word = 0;
        $data_word |= (0x01 && $data[$i]) << $shift;
        $shift++;
      else {
        $shift++;
    // show binary stream to status string
    foreach($data_word_stream as $d){
        $this->status .= sprintf("byte=b%08b\n", $d);
    $buffer1 = "";
    foreach($data_word_stream as $key=>$dataitem) {
        $buffer1 .= iecType::iecBYTE($dataitem);   // register values x
        $dataLen += 1;
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(15);             // FC 15 = 15(0x0f)
    $buffer2 .= iecType::iecINT(count($data));      // bit count
    $buffer2 .= iecType::iecBYTE((count($data)+7)/8);       // byte count
    $dataLen += 6;
    // build header
    $buffer3 = '';
    $buffer3 .= iecType::iecBYTE($unitId);        // unit ID
   * writeMultipleCoilsParser
   * FC15 response parser
   * @return bool
  private function writeMultipleCoilsParser($packet){
    return true;
   * writeMultipleRegister
   * Modbus function FC16(0x10) - Write Multiple Register.
   * @param int $reference Reference in the device memory (e.g. in device WAGO 750-841, memory MW0 starts at address 12288)
   * @param array $data Array of values to be written.
   * @param array $dataTypes Array of types of values to be written. The array should consists of string "INT", "DINT" and "REAL".
   * @return bool Success flag
  function writeMultipleRegister($unitId, $reference, $data, $dataTypes){
    $this->status = "writeMultipleRegister: START\n";
    // connect
    $this->connect();
    // send FC16
    $packet = $this->writeMultipleRegisterPacketBuilder($unitId, $reference, $data, $dataTypes);
    // receive response
    // parse packet
    $this->writeMultipleRegisterParser($rpacket);
    // disconnect
    $this->status .= "writeMultipleRegister: DONE\n";
    return true;
   * fc16
   * Alias to {@link writeMultipleRegister} method
   * @return bool
  function fc16($unitId, $reference, $data, $dataTypes){
    return $this->writeMultipleRegister($unitId, $reference, $data, $dataTypes);
   * writeMultipleRegisterPacketBuilder
   * Packet builder FC16 - WRITE multiple register
   *     e.g.: 4dd90000000d0010300000030603e807d00bb8
   * @return string
  private function writeMultipleRegisterPacketBuilder($unitId, $reference, $data, $dataTypes){
    $dataLen = 0;
    $buffer1 = "";
    foreach($data as $key=>$dataitem) {
      if($dataTypes[$key]=="INT"){
        $buffer1 .= iecType::iecINT($dataitem);   // register values x
        $dataLen += 2;
      elseif($dataTypes[$key]=="DINT"){
        $buffer1 .= iecType::iecDINT($dataitem, $this->endianness);   // register values x
        $dataLen += 4;
      elseif($dataTypes[$key]=="REAL") {
        $buffer1 .= iecType::iecREAL($dataitem, $this->endianness);   // register values x
        $dataLen += 4;
      else{
        $dataLen += 2;
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(16);             // FC 16 = 16(0x10)
    $buffer2 .= iecType::iecINT($dataLen/2);        // word count
    $buffer2 .= iecType::iecBYTE($dataLen);     // byte count
    $dataLen += 6;
    // build header
    $buffer3 = '';
   * writeMultipleRegisterParser
   * FC16 response parser
   * @return bool
  private function writeMultipleRegisterParser($packet){
    return true;
   * readWriteRegisters
   * Modbus function FC23(0x17) - Read Write Registers.
   * This function writes {@link $data} array at reference {@link $referenceWrite}
   * position of memory of a Modbus device given by {@link $unitId}. Simultanously,
   * it returns {@link $quantity} of Words (2 bytes) from reference {@link $referenceRead}.
   * @param int $referenceRead Reference in the device memory to read data (e.g. in device WAGO 750-841, memory MW0 starts at address 12288).
   * @param int $referenceWrite Reference in the device memory to write data.
   * @return false|Array Success flag or array of data.
  function readWriteRegisters($unitId, $referenceRead, $quantity, $referenceWrite, $data, $dataTypes){
    $this->status = "readWriteRegisters: START\n";
    // connect
    $this->connect();
    // send FC23
    $packet = $this->readWriteRegistersPacketBuilder($unitId, $referenceRead, $quantity, $referenceWrite, $data, $dataTypes);
    // receive response
    // parse packet
    $receivedData = $this->readWriteRegistersParser($rpacket);
    // disconnect
    // return
   * fc23
   * Alias to {@link readWriteRegisters} method.
  function fc23($unitId, $referenceRead, $quantity, $referenceWrite, $data, $dataTypes){
    return $this->readWriteRegisters($unitId, $referenceRead, $quantity, $referenceWrite, $data, $dataTypes);
   * readWriteRegistersPacketBuilder
   * Packet FC23 builder - READ WRITE registers
   * @return string
  private function readWriteRegistersPacketBuilder($unitId, $referenceRead, $quantity, $referenceWrite, $data, $dataTypes){
    $dataLen = 0;
    $buffer1 = "";
    foreach($data as $key => $dataitem) {
        $dataLen += 2;
        $dataLen += 4;
        $dataLen += 4;
      else{
        $dataLen += 2;
    // build body
    $buffer2 = "";
    $buffer2 .= iecType::iecBYTE(23);             // FC 23 = 23(0x17)
    $buffer2 .= iecType::iecINT($referenceRead);  // refnumber = 12288
    // build body - write section
    $buffer2 .= iecType::iecINT($referenceWrite); // refnumber = 12288
    $dataLen += 10;
    // build header
    $buffer3 = '';
   * readWriteRegistersParser
   * FC23 response parser
   * @return array
  private function readWriteRegistersParser($packet){
    $data = array();
    // if not exception
    if(!$this->responseCode($packet))
      return false;
    // get data
    return $data;
   * byte2hex
   * Parse data and get it to the Hex form
   * @param char $value
   * @return string
  private function byte2hex($value){
    $h = dechex(($value >> 4) & 0x0F);
    $l = dechex($value & 0x0F);
    return "$h$l";
   * printPacket
   * Print a packet in the hex form
   * @return string
  private function printPacket($packet){
    $str = "";
    $str .= "Packet: ";
    for($i=0;$i<strlen($packet);$i++){
      $str .= $this->byte2hex(ord($packet[$i]));
    $str .= "\n";
    return $str;
So wie ich als kompletter PHP-Laie die Anleitung im PDF verstehe habe ich "function ModbusMaster($host, $protocol)" ersetzt durch "function __construct($host, $protocol)", allerdings wirft Edomi dann die folgende Fehlermeldung im log aus :"syntax error, unexpected 'function __construct' (T_STRING), expecting function (T_FUNCTION) or const (T_CONST)"
Kann mir jemand weiterhelfen???
Vielen Dank
