[V?.?] Connecting topologically distant sensors to the Timberwolf server
zainalara
Beitrag von zainalara »
Hi everyone,
Timberwolf has learned a lot of new protocols by now. What approach would you take if you wanted to connect 10 to 20 immersion sleeve sensors (in a heating system) that are located further away from the Timberwolf server? Ideally, without breaking the bank.
Zuletzt geändert von Parsley am Fr Okt 31, 2025 12:24 am, insgesamt 1-mal geändert.
Hat sich bedankt: 2255 Mal
Danksagung erhalten: 947 Mal
Could you please describe your issue in more detail by including the currently installed version in the title and the important values such as TWS model and ID as well as VPN open and reboot allowed yes/no in the signature. This is the important information that is required.
Hat sich bedankt: 935 Mal
Danksagung erhalten: 478 Mal
Beitrag von Parsley »
The immersion sleeve doesn’t say anything about the type of sensor you want to use. Is it some plain PT1000 or DS18B20 1-wire sensor? Or is it some kind of „sensor-module“ that includes some interfacing circuitry?
How far apart are the sensors and the TWS?
Zurück zu „Allgemeines“
