[Erfahrungsbericht] SMA Sunny Home Manager über Node Red auslesen
MarcusC
Hat sich bedankt: 4 Mal
Danksagung erhalten: 3 Mal
Beitrag von MarcusC »
der wichtigste Grund für mich, vom Wiregate auf den Timberwolf Server umzusteigen, war die Möglichkeit, unsere Warmwasserbereitung an die Leistung der Fotovoltaikanlage anzupassen.(Beim Wiregate ließ sich das entsprechende CPAN Paket nicht installieren)
Wir haben einen SMA Sunny Home Manager 2.0 verbaut. Der Node Red Container ist als host gestartet. Mit diesem Flow (Der auf dieser Anleitung basiert: http://www.eb-systeme.de/?page_id=1240) lassen sich die wichtigsten Werte auslesen.
[{"id":"4c902f85.811b6","type":"udp in","z":"efb43b56.a4341","name":"sma","iface":"","port":"9522","ipv":"udp4","multicast":"true","group":"239.12.255.254","datatype":"buffer","x":130,"y":320,"wires":[["6c1dec45.ea3424","1ed4e1f2.df92f6","139fc0e3.bd458f","8a762b53.9e3bb"]]},
{"id":"1ed4e1f2.df92f6","type":"function","z":"efb43b56.a4341","name":"Aktueller Bezug","func":"var buf = Buffer.from(msg.payload,);\nvar buf1 = buf.slice(32,36);\n\nvar buf2 = buf1.toString('hex');\nvar buf3= parseInt(buf2,16)/10;\nmsg.payload = buf3\n\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":320,"wires":[[]]},
{"id":"6c1dec45.ea3424","type":"function","z":"efb43b56.a4341","name":"Verbrauchszähler","func":"\nvar buf = Buffer.from(msg.payload,);\nvar buf1 = buf.slice(40,48);\n\nvar buf2 = buf1.toString('hex');\nvar buf3= parseInt(buf2,16)/3600000;\nmsg.payload = buf3\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":370,"y":360,"wires":[[]]},
{"id":"139fc0e3.bd458f","type":"function","z":"efb43b56.a4341","name":"Einspeisezähler","func":"var buf = Buffer.from(msg.payload,);\nvar buf1 = buf.slice(60,68);\n\nvar buf2 = buf1.toString('hex');\nvar buf3= parseInt(buf2,16)/3600000;\nmsg.payload = buf3\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":380,"y":400,"wires":[[]]},
{"id":"8a762b53.9e3bb","type":"function","z":"efb43b56.a4341","name":"Aktuelle Einspeisung","func":"var buf = Buffer.from(msg.payload,);\nvar buf1 = buf.slice(52,56);\n\nvar buf2 = buf1.toString('hex');\nvar buf3= parseInt(buf2,16)/10;\nmsg.payload = buf3\n\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":360,"y":440,"wires":[[]]}]
Einen schönen Gruß
Marcus
Timberwolf 950 ID 435 -VPN offen- Reboot nach Absprache
Hat sich bedankt: 1311 Mal
Hallo Marcus!
Danke für deinen Bericht. Mich würde noch interessieren, welche Anpassung du abhängig von der Photovoltaik machst?
MarcusC
Hallo Robert,
wenn genug Leistung da ist, wollte ich die Solltemperatur des Brauchwasser erhöhen, damit die Wärmepumpe anspringt. Wenn die Leistung nicht mehr da ist, wieder auf normale Temperatur absenken. Wir haben uns aufgrund der Wirtschaftlichkeit gegen eine Batterie entschieden und ich hoffe so den Eigenverbrauch zu erhöhen.
Marcus
Hallo Marcus,
eine schöne Lösung. Wärme ist der größte Verbraucher im Haus und dessen Speicherung auch am billigsten und wartungsfrei.
Ich empfehle auch - bevor man mit Batterien anfängt - erstmal das Speichern in Wärme (und damit auch Kälte). Also nicht nur Brauchwasser sondern dann auch Kühlschrank & Gefriertruhe gezielt anzuwerfen, wenn PV-Strom zur Verfügung steht (und wenn man den Raum betritt, damit das Licht im Kühlschrank auch angeht).
Ich kann zwar bei meinem Kühlschrank von außen an der Türe die Temperaturen für Kühl und Gefrierzone einstellen, aber welche Geräte bieten denn dafür eine externe nicht Handy-App gebundene Schnittstelle? Dann wäre das in der Tat ein Maßnahme.
Meine Gastherme macht das mit dem Wasserspeicher ja entsprechend, Gas erwärmt den Speicher auf Temp x und die externe Wärmeeinspeisung (Kamin oder Solarthermie bis auf 95 oder so).
