[V3.5.1] MQTT Mosquitto Socket error
Verfasst: Di Feb 07, 2023 7:49 pm
Hi Forenfreunde,
hat jemand das gleiche Verhalten mit seinem Mosquitto ?
Bei mir connecten die Clients sauber auf den Broker.
Nach einiger Zeit fangen alle an und bekommen nur noch Socket error im mosquitto log und müssen reconnecten, was die Übertragung der Nachrichten verzögert....
Habe es nach dem Tutorial hier aus dem Forum auf den TWS3500 deployed und laufe mit default config. Sprich anonymoous und default port.
1675795354: New client connected from 192.168.195.71 as ESP8266Client-21b0 (p2, c1, k15).
1675795361: Socket error on client ESP8266Client-5e4f, disconnecting.
1675795361: New connection from 192.168.195.62 on port 1883.
1675795361: New client connected from 192.168.195.62 as ESP8266Client-71c5 (p2, c1, k15).
1675795382: Socket error on client ESP8266Client-71c5, disconnecting.
1675795383: New connection from 192.168.195.62 on port 1883.
1675795383: New client connected from 192.168.195.62 as ESP8266Client-6824 (p2, c1, k15).
1675795388: Socket error on client ESP8266Client-21b0, disconnecting.
1675795388: New connection from 192.168.195.71 on port 1883.
1675795388: New client connected from 192.168.195.71 as ESP8266Client-9a68 (p2, c1, k15).
1675795414: Socket error on client ESP8266Client-9a68, disconnecting.
1675795415: New connection from 192.168.195.71 on port 1883.
1675795415: New client connected from 192.168.195.71 as ESP8266Client-4c1a (p2, c1, k15).
1675795420: Socket error on client ESP8266Client-6824, disconnecting.
1675795420: New connection from 192.168.195.62 on port 1883.
1675795420: New client connected from 192.168.195.62 as ESP8266Client-5df8 (p2, c1, k15).
1675795421: Socket error on client ESP8266Client-5df8, disconnecting.
1675795421: New connection from 192.168.195.62 on port 1883.
1675795421: New client connected from 192.168.195.62 as ESP8266Client-24cf (p2, c1, k15).
1675795433: Socket error on client ESP8266Client-4c1a, disconnecting.
1675795433: New connection from 192.168.195.71 on port 1883.
1675795433: New client connected from 192.168.195.71 as ESP8266Client-187b (p2, c1, k15).
1675795448: Socket error on client ESP8266Client-24cf, disconnecting.
1675795448: New connection from 192.168.195.62 on port 1883.
1675795448: New client connected from 192.168.195.62 as ESP8266Client-44da (p2, c1, k15).
1675795451: Socket error on client ESP8266Client-187b, disconnecting.
1675795451: New connection from 192.168.195.71 on port 1883.
1675795451: New client connected from 192.168.195.71 as ESP8266Client-e3f8 (p2, c1, k15).
