[V4.0 IP4] Derzeit nicht möglich einen frischen ioBroker Container zu starten
Verfasst: Mo Nov 13, 2023 11:46 am
Hallo zusammen
leider ist es nicht möglich derzeit einen ioBroker Container aufzusetzen.
Nach Rücksprache mit Buanet liegt es wahrscheinlich an einer zu alten Docker bzw Portainer Version.
Kann das jemand reproduzieren?
Hier mein Container Log was sich endlos wiederholt:
------------------------- 2023-11-13 11:40:41 -------------------------
----- Welcome to your ioBroker Docker container! -----
----- Startupscript is now running! -----
----- Please be patient! -----
----- System Information -----
----- arch: x86_64 -----
----- hostname: ioBrokerTWS -----
----- Version Information -----
----- image: v9.0.1 -----
----- build: 2023-11-11T23:44:48+00:00 -----
----- node: v18.18.2 -----
----- [glow=red]node[22]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (uv_thread_create(t.get(), start_thread, this))' failed.
1: 0xb85bc0 node::Abort() [node]
2: 0xb85c3e [node]
3: 0xbf30fe [node]
4: 0xbf31e1 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8::PageAllocator*) [node]
5: 0xb438f3 node::InitializeOncePerProcess(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node::ProcessFlags::Flags) [node]
6: 0xb43f4b node::Start(int, char**) [node]
7: 0x7f1c236321ca [/lib/x86_64-linux-gnu/libc.so.6]
8: 0x7f1c23632285 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
9: 0xac1f4e _start [node]
npm: -----[/glow]
----- Environment Variables -----
----- SETGID: 1000 -----
----- SETUID: 1000 -----
----- Step 1 of 5: Preparing container -----
Updating Linux packages on first run... Error: Updating failed.
Registering maintenance script as command... Done.
----- Step 2 of 5: Detecting ioBroker installation -----
Existing installation of ioBroker detected in "/opt/iobroker".
----- Step 3 of 5: Checking ioBroker installation -----
Replacing ioBroker executable to fix sudo bug... Done.
(Re)setting permissions (This might take a while! Please be patient!)... Done.
Initializing a fresh installation of ioBroker... Failed.
For more details see "/opt/iobroker/log/iob_setup_first.log".
Please check your configuration and try again.
This Script will exit now.
