[v3.2] custom Logic Problem Error
Verfasst: So Feb 20, 2022 11:58 am
Ich hab hgerade versucht eine Custom Logo anzulegen kann Sie aber nicht speichern.
Ich sehe das Modul mit allen Aus und EIngängen und wenn Ich unten rechts auf speichern drücke kommt eine Fehlermeldung
und oben steht Error
kann mir da jemand sagen wo Ich einen Fehler gemacht habe?
Das ist der Code
Das ist der Code
* New custom logic
"_Meta": { // Optional
"Description": "",
"Version": "1.00",
["Mode","Modus Color o. White","$I_mode"],
["red","red brightness, 0..255","$I_red"],
["green","green brightness, 0..255","$I_green"],
["blue","blue brightness, 0..255","$I_blue"],
["gain","gain for all channels, 0..100, applies in mode=color","$I_gain"],
["brightness","brightness, 0..100, applies in mode=white","$I_brightness"],
["white","white brightness, 0..255","$I_white"],
["temp","color temperature in K, 3000..6500, applies in mode=white","$I_temp"],
["effect","applies an effect when set","$I_effect"],
["turn","on, off, toggle","$I_turn"]
["json Out","Datenausgabe als Json","$json_out"]
["$I_mode","integer"],
["$I_red","float"],
["$I_green","float"],
["$I_blue","float"],
["$I_gain","integer"],
["$I_brightness","integer"],
["$I_white","float"],
["$I_temp","integer"],
["$I_effect","integer"],
["$I_turn","bolean"],
["$json_out","string"],
["$mode","string"],
["$color","string","color"],
["$white","string", "white"]
["Multiplexer",["$color","$white"],"$mode","$I_mode"]
