im Log meiner OpenHAB 1 Installation erhalte ich KNX-Fehlermeldungen.
Das ist die erste Auffälligkeit:
2019-10-18 14:00:03.508 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/10 Licht_EG_Wohnen_Vitrine, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:03.010 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 0/1/60 Licht_Garage, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:06.011 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/6/4 Zirkulationspumpe, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:09.013 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 0/1/60 Licht_Garage, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:12.014 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/6/4 Zirkulationspumpe, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:13.426 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.25.9:3674: connection state response status: server detected error concerning the KNX bus/subsystem connection
2019-10-18 15:35:15.016 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'CLOSED' could not be sent to the KNX bus using datapoint 'state DP 3/6/7 WW_ZPA_Pumpenlauf_Notwendig, DPT main 0 id 1.019, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:18.018 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/1/4 Windalarm, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:21.019 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/1/3 Regenalarm, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:23.426 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.25.9:3674: connection state response status: server detected error concerning the KNX bus/subsystem connection
2019-10-18 15:35:24.021 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'CLOSED' could not be sent to the KNX bus using datapoint 'state DP 3/6/7 WW_ZPA_Pumpenlauf_Notwendig, DPT main 0 id 1.019, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:27.023 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/1/4 Windalarm, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:30.024 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 3/1/3 Regenalarm, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:33.026 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/13 Steckdose_EG_Wohnen_Schrank, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:33.427 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.25.9:3674: connection state response status: server detected error concerning the KNX bus/subsystem connection
2019-10-18 15:35:36.027 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value '2' could not be sent to the KNX bus using datapoint 'command DP 3/6/33 FBH_Modus, DPT main 0 id 5.010, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:39.029 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/13 Steckdose_EG_Wohnen_Schrank, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:42.031 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value '2' could not be sent to the KNX bus using datapoint 'command DP 3/6/33 FBH_Modus, DPT main 0 id 5.010, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:43.428 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.25.9:3674: connection state response status: server detected error concerning the KNX bus/subsystem connection
2019-10-18 15:35:45.032 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/10 Licht_EG_Wohnen_Vitrine, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:48.034 [ERROR] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/10 Licht_EG_Wohnen_Vitrine, DPT main 0 id 1.001, low priority' - giving up after second try: no confirmation reply received
2019-10-18 15:35:51.053 [WARN ] [.b.knx.internal.bus.KNXBinding] - Value 'OFF' could not be sent to the KNX bus using datapoint 'command DP 1/1/50 Steckdose_DG_Flur_Fenster, DPT main 0 id 1.001, low priority' - retrying one time: no confirmation reply received
2019-10-18 15:35:53.432 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.25.9:3674: close connection - no heartbeat response
2019-10-18 15:35:53.437 [WARN ] [b.k.i.connection.KNXConnection] - KNX link has been lost (reason: no heartbeat response on object link 192.168.25.9:3674 tunneling mode (closed), TP1 hopcount 6)
2019-10-18 15:35:53.437 [INFO ] [b.k.i.connection.KNXConnection] - KNX link will be retried in 30 seconds
2019-10-18 15:36:23.439 [INFO ] [b.k.i.connection.KNXConnection] - Trying to (re-)connect to KNX...
2019-10-18 15:36:23.460 [INFO ] [b.k.i.connection.KNXConnection] - Established connection to KNX bus on 192.168.25.9:3674 in mode TUNNEL.
2019-10-18 15:36:23.502 [INFO ] [b.k.i.connection.KNXConnection] - Connected to KNX
2019-10-18 15:36:26.509 [WARN ] [.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'FBH_Absenktemperatur' from KNX bus: no confirmation reply received: timeout
Eine zweiter Tunnel Client (meine Eigenentwicklung) hat ähnliche Probleme und meldet ebenfalls fehlende Confirmations.
Mit dem Wiregate hatte ich diese Probleme nicht.
Peter
